I found a nice set of 4th gen f-body rims (ZR 1 style) I am wanting to put on my t-type.
I have seen a couple of posts around about different manufacturers of wheel adapters. Is anyone running these, there are some at a company called Vette Brakes, another company sells them on eBay. My first question is, who is running these, are you using stock or aftermarket lugs, and what are your impressions?
Second question, are these legal for tech down at the track?
Third question, if you are running C5 vette wheels or 4th gen f-body wheels, what diameter, tire size, and backspacing / thickness of adapter are you using, front and rear? And are you having any rubbing issues, if so how minor/major. I'm not settled on which size of rims to get. 16" IMO looks better on our cars, the sidewall looks a bit short on 17", 18" and larger looks ok on a GN but not so much on a t-type. But the tire size choices are much better in 17". Any additional input would be appreciated. Basically this setup will be for a driver, so I'm basically wanting to improve road handling a bit, not so concerned with strip traction.
