RATROASTER
Davey
- Jun 9, 2003
SignUp Now!I replaced the rear springs. Here's before/after.
What kind of springs did you use??
I bought the springs from Advance Auto Parts they were the OEM replacements. They had many more winds that the stock springs and were much firmer. Cost was $65
WOW..those are stock springs?? How much higher did the rear come up? I'm looking to raise the rear in my GN and inch or so and these springs looks like it will work.
Thanks,
Ray
FYI I had a bad starter. Now the next problem. My passenger side header was tweaked in the accident. I think I can get away with having only the turbo inlet modified to clear the sensor and input piping. If that doesn't work, I'll need another passenger side header. You'll see in the pics that the input bell does not clear the sensor (IAC?).
I would definitely replace that pass side turbo header, as Dave pointed out, your never going to get the THDP to fit correctly.
BW
Decisions, decisions...........should I go for a stock header or go after market?
