SilverSleeper
Senior Member
- May 24, 2001
Just passing along some advice to those new to car audio.
When you are considering any upgrade for your car, a head unit, speakers, or a full blown system, you should ask yourself some questions before leaping into it.
What is the goal of your system?
Cranking bass just to impress someone down the block? Just replacing the blown factory stuff so you can listen to the radio on your way to work? A SQ (sound quality) car? A dB drag (loud bass level) car? And be honest with yourself.
What do you listen to?
Rap? (you want boomy bass) Jazz?( clear mids and tight upper bass) Classical? (sparkling highs and good low extension) Rock? (punchy but tight bass, clear and powerful but not abraisive mids)
How much are you willing to spend?
Will you put in the system all at once, or upgrade little by little? Do you want to replace one thing now, but have room to upgrade something else in the future? Quality costs money, but can your ear actually hear a difference?
When you are building a system, it goes together just like a drivetrain for a car. Putting a big turbo on a small motor isnt going to work. Just like putting a 1000watt amp on a pair of dash speakers is overkill.
I just see too many people these days looking at the pieces and not the system as a whole. They will buy the best speakers, the best amps and use crappy RCA cables, or too small of a power wire, or even keeping the factory deck. The chain is only as good as its weakest link.
If you know what you want when you start in, you wont be disappointed by your system, You wont have to keep replacing your pieces over and over again, and you wont be buying things you dont need.
I have had the same system in my car for nearly 4 years now, with the exception of the head unit which I upgraded 2 years ago, and the subs which were blown and replaced. I set my goals early on, and stuck to them. I bought everything except the head unit and subs once. I still love it!
<dennis miller> Of course, thats just my opinion...I could be wrong!
</dennis miller>
