Where can I buy Plastic Rocker Retainers??
cabech984
Ive been looking online for these & have had no luck. Maybe I havent been looking hard enough. They are the plastic things in the middle of each rocker arm. Thanks!
Chris
the only thing i have see that are plastic and go on the top of the rocker are only used to adjust the rockers. the plug the oil so you can run the engine with the valve cover off. dave
NAPA has them 49 cents each
I believe they are called push pins
