Where to get Silicone Stepped hoses
BJM
Senior Member
I am planning to do the MAF in the up pipe thing and I need to get adapters for 2 1/4" to 3" silicone adapters for using a 3" MAF in the up-pipe. What's a good place to get these things from?
If you are going to use the 3" GM maf as is the 3" hoses do not fit. We have 2 1/2 to 3 1/4 hoses we had made for this install to 2 1/2 pipes
Mike Licht
Mike,
Good to know. That means I would need a 2.5" up-pipe as well then? That would require another silicone adapter at the IC then as well? I have a V4 so the end fitting is a bit bigger than stock already.
