Where to lift engine
thomas_quinn
I have a complete engine with all the accesories, I want to know where I can pu the chain to lift it that it will not damaged anything. Thanks
I have a TTA, but I think the set up is similar if not the same. There should be a tab behind the turbo that makes its way down and attaches to the head. When I had to raise mine I used it plus an intake bolt on the back side if the drivers side head.
Brent
ther is a hole built into the back of the block that you can use instead of trying to use an intake bolt for the back chain hook.
There is?? Never noticed, but I think there is less clearance in the back on a TTA than on a Buick. You guys could stuff a midget with a video camera up front there!!!
Brent
Got two people of lesser stature (Trying to be PC), one holding the video camera and one for surround sound audio mic in the back...j/k. Yeah, that back loop is way back there...
