TURBOELKY
- Jun 27, 2005
Thanks.
Is there a gasket on that turbo intake pipe that I'll need to replace once I break it loose?
Is it easy enough, or worth it, to rebuild one of these turbo's? Even if I go for a replacement (if that's what is needed), I'll either stay with the stock size or possibly one size up. I don't see myself ever dialing up more than 20lbs of boost.
I replaced a few more rotten vacuum lines tonight. Two of the shorties going to the EGR, the shorty going to the cruise control and the shorty at the vacuum canister near the cold air box. The rest are in reasonable shape and I'll have to go buy a bunch more vacuum line to finish all of them off anyway, so I just replaced those that were definitely suspect.
Tim
now that you've got the car running good, you can move on to bolting on some other good stuff. start with the exhaust, get a good 3" down pipe. and a good exhaust set up, if you can find an atr style single exhaust, good! you have enough injectors for a big turbo, I'd go with a ball bearing t61. not too big, but very respectable. and an alky kit, maybe a bigger intercooler, and your done!! oh yeah, not sure if you have one or not, but a power plate....
and a new tranny as soon as that turbo goes on, if not sooner
boost gauge?
