Ya know I've talked to Eric@TT and he mentioned something that really stuck. I've got the good Alky setup but has been on the car for years and primarily sat in a garage most of the last 18 years. Eric said the pumps need rebuilding regularly if over 2/3 years old. Since the chip is setup for alky I'm starting to wonder if my pump is failing. I'm currently leaning that direction. I'll probably have the pump checked and rebuilt at the same time.I can't believe RC is using copper spray on viton coated head gaskets. That's why they leak....
I have installed numerous cometic head gaskets and nun of them leak. I put them on clean and dry per manufacturer recommendations.
Cometics are hands down the most durable head gasket and can be leak free. They just have to be installed correctly.
To the O.P. you better figure out why the the engine is detonating or it don't matter what gasket you use. Something is going to get hurt.
