turboc87gn
Darkside in Detroit
- Oct 2, 2008
Im in the process of putting together a new combo for the gn and the plan will be mid tens with ported irons on e85...The shortblock im buying has je pistons, head studs,stock rods,Buick motorsport crank, stock stroke,stock caps
It went 10.20s in a buddy of mines full weight gn... He took it out to install a DLS 4.1 ...My cylinder head guy finally finished my heads he used Comp Cams Ls1 Beehive springs,(up to 550 lift with a hydrualic roller)
I was wondering what headgaskets to use? He had a GM Turbo Buick V6 complete gasket set laying around... He port matched my heads to the intake gasket...I read rjc blowproof gaskets were patterned after these,are the GM gaskets the best for my application?
