usetaboost
SAY CAR RAMROD!!
- May 4, 2005
But all of our maf pipes are metal
Plastic also=less weight....well sometimes
SignUp Now!The SFI puter system is a lot more sophisticated than the hot-air cars. The hot-air stuff is more like a ball-park adjustment. So MAPS, O2, TPS, BARO, and TCC dealt with fuel control on a narrow range. Those sensors are worthy of keeping if the OEM hot-air puter system is to be maintained. The other emissions stuff on the hot-airs was the real concern by OEM, (albeit crude). Most of it was junk anyway after five years. This included various vac sensors and carb canister stuff along with the A.I.R. pump and the cat.
But all of our maf pipes are metalPlastic also=less weight....well sometimes
If you don't have emmisions you can get rid of the canister but if you plan on having the puter do it's job it may set a check engine light. If you put the filter behind the head light it would be easiest.
Removing the charcaol cannister will not turn on the Check Engine light.
Don't plug the hoses from the cannister to the carb.
Good idea Walt. It'll also help you identify how the body is put together if you need to do a repair.
Should be in the performance air filter section but if you go to a store they should have a seperate catalog that will give the info.
^^^ You said thingy. HE HE HE:biggrin:
I was trying to keep it simple for him Freddie. He's not just a newby but green as well.:smile:
Well I have seen someone make a pipe out of PVC tubing. Kinda ugly but very functional.:biggrin:
so its safe to take out without any reprocussions?
There is no benefit to removing the charcoal cannister unless you need room for something else. It's just a big charcoal filter to trap gasoline vapors from the fuel tank. Removing it won't hurt anything engine-wise. Might lead to global warming though. :wink:
I have a motor Manual for 1976-1983 buick regals.
Get the Chassis manual from Buick, it's MUCH better!
1983 BUICK CHASSIS SERVICE MANUAL ALL SERIES -- BIG:eBay Motors (item 370258757784 end time Jan-08-10 21:51:04 PST)
^^^ This will make the book you have look like a childs book. He's not kidding. Get the book.
ok.. but cant afford it.. I either gotta get gas or the book. Ill think of it as an investment.
