SignUp Now!I also agree with the fuse idea,,,but what about coolent damage to the crank bearings......how can we stop that
You might get more accurate results if you included a goal ET in your poll. example: What headgaskets would you run if you're shooting for 11's? Just a thought because if you're running 12's there's (IMO) absolutely no reason to run commetics, but if you're running 10.0x then it might not be smart to run 9441's.HTH james
Of you guys that voted "other" ....... what head gasket are you running.....? and why?
you hit it
Shame on you for letting me wander aimlessly
:biggrin: no problem .... seriously the stock headgaskets I ran for a "fuse" since the beginning of time was for a mid /low11 car .. not saying ya can't run them in the 10's BUT I want a little stronger headgasket for when we start to push
I just don't want to be one of those that gets fast at changing head gaskets.
I believe the "toyota red" is organic acid based. I've read the organic acid antifreezes are not compatible with copper, brass, and soldered joints. If one has a stock or stock-like radiator, that could be trouble. The cabin heater-core could also be another trouble spot.Run toyota silica free anti freeze. Wont hurt your bearings since there is no silica in it.
hey don't make fun of me :biggrin: they call them "tricks" to get them done faster
