We built many turbo engines with the bearing tolerances you stated.
If you would actually check the published Buick factory specs for a turbo V-6 you will find none?
All the V-6's from 110 HP and up are all grouped together? If you check the Buick Power Source listing for a turbo build you will see they are right on the mark of what you have.
Ever seen a used up rod bearing that was the same thickness as a sheet of paper?
I removed one yesterday like that as the owner heard a noise in the engine. Only one half was left in the rod, the other half was only pieces in the pan. A local production shop did the build.
In the many hundreds of engines we have built, never have had a rod bearing be trashed for being too loose? I have personally beat the hell out of a few pistons, but never took out a rod or main bearing.
Detonation will kill a rod bearing, so will the clearance being too tight.
