Which One
BOOSTWANTER
What Other Transmissions Will Fit In The Turbo Regals Besides The 200r Because Im Looking To Buy One
You can make about anything fit, but the easiest swap would likely be a TH400 due to the crossmember location, BOP pattern available, and approximate length and size.
A TH350 would also go in relatively easy, a 700-R4 can be made to fit.
Why not a 200-4R?
If this is a driver, and not a racing setup, you don't want to give up the OD.
im hearing so many stories about these trans its ridiculousim just sick of my trans pausing in between 1-2, and everytime i adjust the tv cable it doesnt make a change in performance at all, read my post called help, and you'll understand what im saying
