SignUp Now!you're not gonna get a "your car is the 3,864th GN built that year" answer, if that's what you are looking for... but with a date you can get an approximate range probably within a thousand or so..
my 84 T Type was built in December of '83.. they made 2000 T Types that model year, and i think i read somewhere that they started production in september or something like that... so my car is probably one of the first 500 or so TR's built with the EFI engine , overdrive trans, and 8.5 rear end.. not that i really worry about these kinds of things- but it's kind of cool to know..
Sweet, I'm gonna go get that checked out maybe someone has one close to mine so I know which exact one it is.
Mine is 458556 - a little closer!
Get this - based on your production date, mine was made late Sept / early Oct. It wasn't SOLD until close to the END OF JANUARY 1988!! I can't believe the thing sat around for almost 4 months before somebody picked it up!
My GN was built during the second week of October '87 and they built 612 Regals between yours and mine. Since all Regals got their serial number from the same 4xxxxx series we don't know how many GNs were built in Oct. The last GN built Dec 11, 1987 has number 465288.
The body plate, located on the driver side cowl, has this info. Look for first series of digits on the upper left corner of the plate. First digit is a letter that designates year eg "h" is a 1987. Second two digits are numbers that designate month of production eg "08" is August. Fourth digit is a letter that designates week of the month eg "c" is third week.
thats common known info .. but
on any other 87 model other than a GN the cowl with a 09 for month would have a sept 1986 build date because the standard GM model year would have been sept 1 1986 to aug 31 1987
but the 87 GN has a quirk ..they ran an extended model year so the 87 gns were built from sept 1, 1986 through dec 11 1987 (this was a first in the history of GM to my knowledge)
so you have to take the vin sequence number into consideration to know if its built in 86 or 87
the door decal would show a 9/87 if it was late build
