Carl,
What I meant was will this go ok with this cam for the street... because this will raise the valve opening more. And giving it the characteristics of a cam with a different grind.
Bison,
This is Mike's cam kit at Fullthrottlespeed 210/215
Intake 210 @ .050 .516 lift
Exhaust 215 @ .050 .516 lift
110 L/S (installs at 110)
(lift with stock rockers)
(lift with stock rockers) = 1.55 So .516(lift)/1.55(stk ratio)=.332 actual valve lift
.332 X 1.65= .5478 lift with a 1.65 ratio rocker
The springs I will need to dig a little deeper the website says " "BEEHIVE" SPRINGS FOR BUICK ROLLER CAMS"
This is from car craft "Math Anyone?
If you're not sure what the valve-lift numbers will be with a larger-ratio roller rocker, then get out the calculator as we fill you in. Take the intake/exhaust lift numbers from the cam catalog and choose one side to begin with. For example, the Comp Xtreme Energy 268H has 0.477-inch lift at the valve on the intake side. Since the 350 comes with a factory 1.5:1 ratio rocker arm, we take 0.477 and divide it by 1.5. This results in 0.318 inch, which is our lobe lift on the intake side. Next, take 0.318 and multiply it by the new arm ratio. With a 1.6:1 rocker, this gives us 0.508-inch valve lift at max lift, an increase of 0.031 inch. It doesn't sound like much, yet it was enough to show a sizeable gain, mainly because it increases the amount of time that the valves are open at higher lifts, allowing more air to flow through the heads. The valve will now see 0.500-inch lift twice during each combustion cycle (once as it opens and again after peak lift on the closing side)"
Chuck
