Which spark plugs would you use on GN-1 or TA heads
norbs
Classic fast, XFI, SPortsman & MS3 programming
I am planning to go back to the dyno , and want to put a new set of plugs in that would be good for about 32-33 lbs boost, not being to hot. I have the TA aluminum heads, but I'm sure the champion heads would use the same. Has anyone had good results with a certain plug at a certain boost?
thanks norb
might better go back and ask t/a. my brother and i both have champions aluminums,, i have autolight 104s in mine he has autolite 23s or 24s in his??go figure??
I have autolite 23's in my TA heads.
It will work better if you use a long reach plug in the TA heads, as that is how they were designed.:)
If boost is 30 psi or so, I would run a cold race plug like Autolite AR3932.
Thanks for the info, everyone.
