alwayscode390
- Apr 2, 2009
Can you use a Ford "remote" Starter Solenoid 1/2 between the igntion and the starter to fix a weak solenoid to ignition contact? I had a weak starter in my 67 Camaro and used one with some advice of a friend, and the starter is REAL strong now. Just curious
Also , I bought two starters a few years ago ... and I forgot which is for what engine. I either purchased them for a 96' LT1 camaro , 67' 327 camaro, or the Syclone (small block style). Will they work for our TTA's? If I can use one ... which would you choose?
Left:
Cast AC DELCO 10455709 - Gear Reduction Starter Assembly
- Mini High Torque Starter for LT4
Fits: 1992 - 1996 Corvette
Technical Notes: Use with 12 3/4" OD flywheel.
V8 5.7L 350cid GAS FI N Engine VIN = 5
V8 5.7L 350cid GAS FI N Engine VIN = P
Says Denso on a sticker, it may be rebuilt.
11 tooth gear.
Right:
No Casting, Looks new , but looks universal (billet mounting block ). Generic? (512 282 stamped in ink)
starter gear sticks out 1/2" more than the ac delco one
electrical posts in the rear use one male and one "plug in type"
Its the same size as the AC Delco one , so I am GUESSING its a high torque one too?
A search related it to a Bosch Preferred Pro part, but I am not sure.
11 tooth gear
Thanks ---
Left:
11 tooth gear.
Right:
11 tooth gear
Thanks ---
