Wished i could have been in Reynolds, but i didnt know it was the same weekend as this local shootout.
I got board and just went ahead and overlayed the upgrades over the old combo, and posted the timeslips.
Its not the fastest, but not bad for first time to the track with the new setup and its only been on the car for 3 days
Passes were at 27 psi, 14 psi launches, 28° and 24°
It boggs a little with the larger turbo and the stock convertor, but im not going to complain one bit.
It was worth adding the turbo to the car. :biggrin:
60' 1.63
330' 4.67
1/8th 7.22
MPH 95.37
1000' 9.43
1/4 11.29
MPH 121.13
60' 1.65
330' 4.67
1/8th 7.226
MPH 95.56
1000' 9.43
1/4 11.288
MPH 121.40
60' 1.58
330' 4.597
1/8th 7.15
MPH 95.21
1000' 9.370
1/4 11.237
MPH 120.64
60' 1.606
330' 4.62
1/8th 7.170
MPH 95.49
1000' 9.38
1/4 11.250
MPH 120.80
60' 1.569
330' 4.577
1/8th 7.121
MPH 95.62
1000' 9.334
1/4 11.195
MPH 121.17
60' 1.594
330' 4.612
1/8th 7.160
MPH 95.39
1000' 9.378
1/4 11.241
MPH 120.95
If its in bold, those are the changes over the 11.76 at 114 passes
RACE WEIGHT: 3595 WITH ME
BLOCK: Stock 109 Motor never been out of car
HEADS: Stock 8445
CAM: Stock
TRANSMISSION: Stock 2004R
TORQUE CONVERTER: Stock D5
DIFFERENTIAL: Stock 8.5 3:42 gears and stock axles
INTERCOOLER: Kenne bell
http://i103.photobucket.com/albums/m...n/100_0874.jpg
THROTTLE BODY: Stock, not even semi ported
RJC POWER PLATE: YYYYEEEEESSSSS!!!!
INJECTORS: Stock 90,000 originals
009 42.5 LB
THERMOSTAT: ATR 160°
TURBOCHARGER: Stock 87 turbo regal, portmatched compressor housing to inlet bell
TA 61 WITH GARRETT EXHAUST HOUSING ( STOCK STYLE)
VALVE SPRINGS: Stock 90K originals
MAF: LS1 3.5 with Mark Hueffman cold air kit
DOWN PIPE: MPE Keith Mease 3" S.S. downpipe
EXHAUST: Nonexistant, just downpipe
FUEL PUMP: 340m with Kenne Bell hotwire relay
FUEL PRESSURE REGULATOR: Stock TTA 237, non adjustable
FUEL PRESSURE: 47psi
ALCHOHOL INJECTION: Yes, writeup about it here DIY- Junk drawer DIY kit, SMC controller, Sureflow pump,m-10, 1/8th ss line...
PROPAIN INJECTION: NO
NITROUS: NO
AIR FILTER AND AIR INTAKE: Mark Hueffman 4" to 3.5 at MAF
TIRE DESIGN, SIZE & AIR PRESSURE: M/T 28x9.0 ET drags at 12.0 psi cold
13.0 PSI COLD
AIR BAG(s): 1 on pass side rear, 20psi
25.5 PSI
SUSPENSION: Missing front swaybar and endlinks, boxed rear uppers and lowers, air bag 20psi and ATR rear 1 3/8 sway bar
SCAN TOOL: Scanmaster 2.1
FUEL: Either 110 Turbo blue OR some type of Blue 112???
110 TURBO BLUE
CHIP: TT Eric Marshall TT chip made at the nats for my grey car in 03?
TURBO TWEAK CHIP BASE SETTING 26°- 24°
CHIP TIMING: 27° in first and second 25° in third
28° IN FIRST AND SECOND 24° IN THIRD
KNOCK RETARD: .5 or 1.0 MAX entire run
.7 MAX
OXYGEN SENSOR VOLTAGE: With SMC controller at 4, its 760's at 22-23psi
SMC AT 6
EXHAUST GAS TEMPERATURE: NO EGT
TRACK ELEVATION: LESS THAN 800 feet
TEMPERATURE: 55°
60°
PEAK BOOST: 23
27
BOOST AT LAUNCH: 10psi foot brake
14 PSI LAUNCHES
MILES ON THE CAR/ENGINE: 90,150 ish
90,250
