Jerryl
Tall Unvaccinated Chinese Guy
- Dec 14, 2004
Actually, billet caps are a PAIN to install, and REQUIRE machine work. They are NOT a simple bolt-on. Line boring and honing (and usually elongating the stud holes, too) are required to get them to line up. This also requires the use of a shorter timing chain, too. The cap installation needs to be done by a competent machinist, or they can screw up your block. I personally prefere a girdle over steel caps. I think it does a better job, and it only requires a line hone, not a bore. The reason to use either caps or girdle, is that the main caps are pretty weak. I've seen lots of broken ones. If you have the money, now......do it and be done with it.
+1
Besides the line boring, timing chain etc issues, you can also get misalignment from the trans input/converter.
Maybe not much to worry about, but, still misalignment.
LOTS of "junk blocks" because they are machined incorrectly for caps by incompetent machine shops.
Skip the caps, get the crank and install a girdle!
