I just installed a 305/200-4R combo from an 89 caprice into my 56 Chevy truck. I need help diagnosing the upshifts. Under acceleration the RPM goes up normally then jumps higher for a full second just before a normal upshift. It feels like a quick downshift then an upshift. The fluid is clean red, I adjusted the tv cable, didn't change anything. The other abnormality is the trans won't spin the speedo cable, so the vss is crippled and I had to bypass the ecm and wire the TCC to lock-up in 4th when the brake is not applied. I may have screwed this up but I don't see how. The trans came out of the donor car extra clean, with a new pan gasket so I"m guessing it's been recently rebuilt or repaired. Any insight?
