Will this make my car faster?
TURBOV6
"SECRET PARTS"
Staff member
I'ved been having good luck with Joe Lubrant's chips, one race with 26 degree timming and a street with 20 degree timming. I also got a Jim Testa race with 24 degree timming in it still a good chip but seem to loose about 5mph with this chip. All of these race is for 110 leaded gas and about 22-24lbs of boost..
If I got a different chip with higher timming/octane will I got bit faster? Maybe a custom chip from Red Armstrong's (30 degree timming with 116 leaded gas) or a ATR strip chip?
As long as you are not getting knock, you can add more boost or timing, and go faster. I'd just send one of your chips back and have them change it. It's cheaper to have a chip changed than it is to get a new one. Red charges $75 for the first chip, and they are almost always pig rich on the bottom end.
I would say you are still off a good bit. I have seen a little less combo than yours go 11.3-11.7 many times.
Re: Re: Will this make my car faster?
I'm trying, been trying tunning with boost and fuel get around 780's WOT 02's with no knock. I got around 111 mph before but my car seems to max out around there. Maybe some higher octane and like 26lbs boost?
But Joe not there anymore will the chip still be the same? Anyone know how much it will run?
