Rich, not sure if there's any secret. I went to Comp USA and bought a USB to serial adapter and it works fine. You do have to set up your com ports though. I also have a brand new Dell.
Originally posted by Buicksx2 Thats what I did and it won't connect, what exactly do I have to do with the ports? Keep in mind computer dunce here........lol.
1) Right click on My Computer and pick properties.
2) Select the Hardware Tab on the menu that appears.
3) Click on Device Manager
4) Under "Ports (COM & LPT), you should find your USB --> Serial Adapter.
5) Pick proper port from #4 above and select properties by right clicking on that object.
Inside that menu, you can change the port to any free COM port. You have to use a port between 1-4 for C-COM. Usually, COM1 will be taken by the internal serial port in your laptop, so you can use 2-4.
