Seeking advice on a driver's side windshield pillar gauge mount. Looking for either a single or dual gauge pod that mounts up high near the roof. Want to mount at least a boost gauge. Maybe one of the new round Scanmasters. Would prefer that the gauges & mount are hidden as much as possible. What vendor has these available that fit correctly?
Do they interfere with the sun visor?
Are they available in colors that match the interior, or require painting? My interior is Camel colored.
What make, model & size boost gauge is recommended? How about the scale? Typically display 30" vacuum, to 30 psi boost? Or 35 psi boost?
How about running the wiring & vacuum/boost line as clean & unobtrusive as possible. Can the after-market gauge illumination usually be adjusted without making the dash lighting too dark?
Any other advice?
Thank you.
Any other advice?
Thank you.
