With your help the dream continues
Pm me your address or were you want the parts to go and Ill see what I can put together.
Hey guys,
Anybody who feels like they want to donate money can do so to Jerryl. I have talked to him and he had agreed to handle the money for this project.
Thank you all for your help!
Post this paypal addres . .
Jerrylnai @ yahoo dot com
Of course as a gift is best. Thank you all again.
Jay
Ok Im getting things packed up so mark this stuff off your list. I will ship out Friday or Saturday.
Headers/cross over
Fuel rail
Adj. Fuel press regulator
Oil dip stick
Fuel lines from frame to rail/regulator
Ignition mounting bracket shape like a U. I don't have the one for the bottom of module.
Hey, thanks for stepping up guys. I've only had a few minutes today to check on this. (14 hour work day today)
Headers/cross over
Fuel rail
Oil dip stick
Thank you Mike! I am very appreciative off this!
No problem just glad I can help out. Hope your cruising in your car very soon.
Things Needed: Updated list
intake manifold
Ignition mounting brackets
Plug wires
Starter
Alternator
Power steering pump and hoses
Power steering reservoir
AC compressor and hoses
Crank sensor
Cam sensor
.005" undersize timing chain
Down pipe
Motor mounts
2 metal support brackets for acc bracket
Turbo
Intercooler
MAF or aftermarket with Translator
fuel pump Hot wire
Fuel filter
Turbo mounting bracket
Turbo drain hose/tube
Throttle body
Throttle/TV cable mounting bracket
Coolant temp sensor
Oil pressure switch
Throttle position sensor
Oil pan
Oil pick up tube
Gaskets
Rod/main bearings. (I'll measure what is needed later)
Rear main seal
Add to the list .040" pistons (preferably JE stock replacement, as that is what the crank is balanced to,
Torque Converter
Thanks so much, I am feeling so blessed right now!
Jay
Did I miss it? Where do you want parts sent?
I will see what I have that you still need.
Look forward to seeing you in your GN.
Folks, I only need the parts to build the long block. Send the external stuff to Jay. It can be installed during install and save shipping costs for the engine. Not sure what shipping a long block costs. Any one have a rough estimate to ship a long block from Seattle to Illinois? Cash donations can be sent to Jerryl.
Unless Jay sends his car to me to finish the install. Then he could fly out and drive it home. Hopefully he will soon be employed full time and not have the time to fly out and drive it home.
I might have some ignition parts and other things. I'll take a look.
God knows I would love a job! I keep trying. After a very interesting conversation with Mike B (Spoolfool) I have some New food for thought.
Anything that you guys wanna send to my house is greatly appreciated. Please send it to
Jay Denning
24736 N Copperas Creek rd
Canton, IL 61520
I am sorry for the confusion guys thank you
I may have missed. Hot air or 86-87? I have pieces for an intercooled car.
I know I have a set of Taylor 10mm plug wires w/barely 5K miles on them I can donate.
I might have a GN1 external waste gate DP I can pitch in, too. However there is a caveat. The reason it was removed is the waste gate stuck twice. Not wanting to chance it, I switched it out for a TH style 3 inch pipe.
Someone related to this project let me know if you want it.
Guys, I have the following:
-Alternator (need to check it at auto zone first)
-Cam sensor (missing screws)
-Stock Intercooler, shroud, screen
-Coolant temp sensor
-Throttle position sensor
-Oil pan (ugly but works)
-Gaskets, I think 100% complete plus all the upper gaskets; TB, etc
-Rear main seal
-Torque Converter (stock D5...) would suck to ship but will if you don't have a better converter or one closer.
-Cam bearings
-Vac block & screws
-IAC block & screws
-New AC Delco PCV valve
-Timing indicator
-Oil slinger
-New IC hose set & clamps
-Lucas break in oil additive w/ zinc
You want the gaskets, rear main, cam bearings, and slinger sent to turbofab and the rest to you?
Let's get this thing on the road!!!!!
