SignUp Now!Order a .85 after you go 110+mph in the eighth.
were you running through the exhaust or cutout?I ran a 6265 with both a 85 housing and a 63 housing. Running at 26-27lbs of boost with ported heads the trap speed was basically the same. Actually the 63 trapped 1 MPH faster but maybe the conditions were different. This was trapping at 125-126 to give you an idea of where I was at. The spool up was quite a bit slower with the 85 as well.
you really need to have the boost way up there for that .85,always slowed down and lost et with the .85 vs .63 on 49,62/65,and even on a billet 64mm strim.the .63 pte and tnetics .63 have been 9's.im currently running mid 10's and track tested a mph loss and et loss when running the larger .85 housing
how do you think the .85 would have done through the exhaust ?At the track dump open with both.
wow old thread, but at that time I tried both.ive gone a lot faster since and going through a good exhaust isn't giving up much to an open dump.Was this through the exhaust or dump?
