blackgn231
Money pit
- Mar 28, 2007
I have tried plastigage and the feeler gage method with out a gasket and with a gasket . I am feet different readings every time . It’s driving me crazy . My motor is installed in the car had a oil leak so took the adapter apart to replace the gasket . . Do you need to take the reading on the drive gear ? When I use a straight edge across the gears the idler gear seems to still have play a little up and down . But drive gear is tight . Is there any other way to do this ? Tried .005 , 007 and .008 and with plastigage it does seem to be tight enough to get .002 clearance . I really need help with this .
