Fresh rebuilt with 370 miles. The motor sounds and runs great, then I started noticing the bad oil leaks. The intake manifold and valve covers are dry. I found oil coming out of the oil dipstick tube and oil spray all over by the steering column area and the rear main seal area. I have 2 breathers and a new AC delco PCV valve working properly. I pulled out the breather and it was alot of blowby gases so I then use a smoke machine and introduce smoke into the dipstick tube and the smoke came out strong from the rear main seal. M rebuilder came down and seen it. He says maybe the knurl markings on the steel crank cut up the Felpro 2 piece seals and it appears to be for the rope type seal. The knurl marking for front is the same as the rear and I am using a neoprene seal with no leaks. He claims that he uses Sealer Power rings for my TRW pistons, gap them correct and install them 180 deg apart. He suggest that I should perform a leakdown test and check the spark plug running conditions. Can excessive blowby damage the seal? Or did the crank tear up the rubber rear main seals? I bought a steel crank from TR customer. Have anyone encountered this kind of problem? May need to pull motor apart again. Any help will be appreciated.
