turbo96max
im going to be using aftermarket sending units to wire into the xfi inputs and I'm wondering if I still the oem oil pressure sender or not. Does it even have a dummy dash light or does it affect ecu function??
You should have an oil light on your dash. It should go out just as you are cranking your engine, or most likely, just a moment after the engine starts. This is what this sensor does.im going to be using aftermarket sending units to wire into the xfi inputs and I'm wondering if I still the oem oil pressure sender or not. Does it even have a dummy dash light or does it affect ecu function??
thanks , didnt know about that additional benefit to the fuel pump . will keep it in there thanks !! (; doing a diy logging kit <50 bucks w those chinese senders , seem to work ok so far
dayum hahaha I ran one logging fuel on e85 and powerlogger for almost 3 yrs no leaks. I may take them to a hydraulic supply and test for burst pressure. You seen them leak ? Have I just been lucky maybe ??Chinese senders.![]()
Yeah I saw a pic Nick posted and kept that rail gauge in the box afterwards !! I have time to decide by the time the engine makes it In the car I may have funds for high end logging kit.I've seen a lot of overseas parts fail. A lot of rail pressure gauges that leaked too. Why risk it?
What's 2-300 bucks more after 10k
Yup and it connects directly into the egr harness so I read a big bonus. Need to figure out the caspers box switches
I saw that vid you posted under water and was immediately convinced lol. Going to thread it right into the upper plenumApparently too much. I've seen some running the plastic MAP sensors on $20000 engines still.
I'll ping you when I'm ready for the logging kit . Doesn't make sense to cheapout there. And not take advantage of the logging benefits/features. Have you ever tuned remotely by logging into team viewer or some remote control application on pc?
