XFI fan wiring question?
Blazer406
Mechanical Engineer
Does anyone wire one of the outputs on the XFI (in conjunction with the normal fan outputs on the XFI) to cut the fans off after a certain speed is reached? Seems like dual fans running at 40mph or more is just buring un-necessary amps..... amps that might be needed elsewhere..... and if you were on the interstate... that extra power required to generate that 40+ amps is sucking more gas......
Just wondering.
Just a thought, but if your running hot enough to have the fans running at interstate speeds you have more serious problems than generating too much power.
I was only talking WOT.... like at the track.... using an output to cut the fans off....
The fans already turn off at WOT provided your TPS is calibrated correctly.
