NY Twin Turbo
All the good stuff.....Times 2.
- Dec 10, 2014
Does anybody think it would be a better strategy to base percentage of correction on map instead of RPM?
Long ago I was able to tune my individual exhaust gas temps within only a few degrees of one another. Under moderate to heavy load points it's very consistent. It's this area of the map that is most important to me anyway. I don't see a lot of variation beyond the 7 degree increments the XFI reads temperature in. I always correct +/- against the cylinders that are naturally the same or the one that's in the mid temperature rage. No one could ask for closer numbers. It's beautiful.
However, The lighter load points can be a little all over the place. 50-100 degree differences is not uncommon. I'm not going to chase the perfect EGT temps forever. Just making an observation, because the RPMs are the same. It's obviously the MAP that's different.
