SignUp Now!Originally posted by Gmachine
I'm having a boost creep problem and someone said that the GM orfice hole was too small at one point and it could be drilled larger.
Mine now is .050 IN big.
Thanks in advance!
Ryan
Originally posted by John Craig
.050" is the size it should be. If you enlarge it, you remove the
ability of the computer to control the boost. What is the model of your turbo? Which line is the orfice in? How much boost are you trying run?
Originally posted by OKTurbo
Why not just get one of these....don't have to rely on getting the right one from the dealer.
http://secure.johnsperformance.com/images/large/large-orifice.jpg
Originally posted by tcgn
Thanks OK TURBO.I`ll order one.
I was told by a guy who has worked on these for 30 years .052 drill bit is correct. It was very hard to find a bit that size. Found one at ACE.Originally posted by Gmachine
I'm having a boost creep problem and someone said that the GM orfice hole was too small at one point and it could be drilled larger. Mine now is .050 IN big. Just wondering how much larger I should go, or if this was OK.
Thanks in advance!
Ryan
