You listed the backspace as 6.7 with a 1/4 inch spacer. That seems like too much backspace or maybe it was a type error.I'm not sure what you're asking.
The wheels may not be out of round like you think. Factory wheels are hub-concentric and aftermarket can be lug-concentric. You need to find someone that can check the balance with a finger adapter. The fingers go in the lug holes to center the wheel on the shaft, not through the center hole.
... And for the record, I drove like crap. DFL. But the car works. My harness bruised my chest.
I'm not sure that I agree [about your driving]... looks very smooth. That has to be quite a rush.
I hope that you are having a good time no matter what
You are certainly enlightening quite a few folks Nice work!
]I finally swapped out for a manual master. Telemetry shows I'm able to brake at least 1G, so I think the only thing you'd gain from a hydroboost is extra weight and flat spotted tires. I am very much looking at the new aluminum drums Kirban is about to start selling. I think with the reduced weight and better heat shedding, they might be almost if not just as effective as a rear disc conversion without any of the cost or hassle.
Was that the Roadster Shop C10? If so that thing runs pretty damn good, I've seen it at Good Guys Fort Worth. Sounds like your car (and driving skills) are doing well! Keep it up.
This is interesting to me. I personally love the feel of manual brakes but I've only had them in small and very light vehicles. Vac brakes are very spotty on my car.
Turbo6inKY would you share your alignment specs?
