BoostnTtype
 - Mar 11, 2008
im going to the track tomorrow and i wat just wondering the times you guys think i will run...
86 T type..
67mm turbo,60lb injectors, percision front mount IC, rjc plenum, spacer & 60mm throttle body, 3200 stall, turbo tweak chip, 3" down pipe with tial external waste gate....These runs will be one a hoosier drag radial on 19/20 lbs of boost using 93/110 mix
			86 T type..
