johnplogii
Senior citizen
- Aug 13, 2005
Just throwing this out there as an idea.....
Some time when I know I'm going to Glenwood and you'll be there for sure, I should bring up my Mark Hueffman big mouth cold air kit and ls1 maf/translator/3.5" maf pipe setup to see if it makes any difference. If it is going to gain anything on anyone's vehicle it would be on a low 10 car running the stock maf. I bought it only because it was shiny and I wanted the more reliable MAF so I won't be disappointed if it doesn't gain anything. Would only take about 10 minutes.....
You probably remember me. I talked to you one night up at glenwood. My buddy says your back wheels/tires almost bottom out when you launch, but I couldn't check it out because it was your last run (on a different night when I think you made the finals, maybe the night with the rocket cars and such). What do you run for air pressure in the rear?
Bob Koch
The larger maf & pipe may help some but do you have to run a different chip for the translator? I gained a solid .10 & 1.5 mph going from a stock to 62mm throttle body. Definately let me know when you plan on coming up this way. I run around 10psi in the slicks. I know what you are talking about I have seen pictures where it looks like my rim is almost in contact with the ground.
