chipsbuick
87 GN 10.87 @ 125.74
- May 26, 2006
Here is a run I made 2 years ago at Island Dragway off the foot brake. This was on drag radials and Pump gas spraying Methanol. Car has 70 MM turbo, Lock up Converter (5 disc)trans built by Vince Janis,3.23 Gear Ratio, 83 lb Injectors, 2 pumps in Tank, -8 Fuel line, RJC Front Mount Intercooler, Turbo Tweak Chip. Converter is too tight causing some lag and bad 60 foot times.
This fall I am going to change converters and see what she will do.
