- May 26, 2001
I'm about to pick up a block, and I'm wondering what I should go with. I really just want something really torquey, that can run mid to low 11's. I was also wondering what would happen if I were to run 8.75 instead of standard compression pistons. What's working for you now, and what do you recommend. All help is appreciated.
Thanks!
Over the years with turbo Buicks, the best "bang-for-the-buck" I have found is built a 4.1 with good flowing heads. :smile:
My personal favorite [which is still running around in CA] was a 4.1 with alum heads and a TE-45A. Low end and mid-range torque was awesome, lots of fun on the street. On the strip, an easy high 10 sec. beast. This was a VERY low cost engine, block was $50, had a standard stock crank and got a good deal on the heads.
Recently put a 4.1 in a local street GN that trashed his 109 block. Used his ported iron heads, a V-4 intercooler, and this was a torque monster on the street!
Good tires were a MUST as first and second gear shifts would lite them up at half throttle.
You need turbo pistons in a 4.1, not the inadaquate hyper crap. The 8.75 CR is where I would go with it as well. Special pistons not required for thar CR if your engine builder knows how to properly build, and set up the block and heads.:smile:
This will give you more low and mid-range torque than a stroker kit with lot less $$$$.
P.S. My alum engine is a 4.1 using a stock stroke forged crank, and has run 9.60 @145 MPH!:biggrin:
