109 block
84beastregal
I have a 109 block with out drilled drain hole bored .20 over speed pro/sealed power Pistons gn turbo rods from highway stars needs crank cut or a new one have feed line with fitting for turbo and a set of arp head bolts for info text 2243219195 local pickup Waukegan ill asking $400
Was it just bored .020 over and the pistons and rods are new? I am in the Milwaukee area
Have 2 sets of stock 8445 heads to go with not the ones in the pic
Forgot to mention it will need new cam bearings put in shop I took it too didn't seat them on right so it scratched them up don't have more pics lost all the ones I had but I can get you some if interested
I maybe interested.. You said it is fresh from the machine shop with new pistons and rods? Along with a set of heads?
Not fresh out we ran it for like 50 miles but something wasn't room so we pulled it nd all crank bearings wer scratched up and the cam bearings need replaced but yea you can say it's fresh and yes new Pistons nd rods and 2 sets of heads that need cleaning
