Those 3 original rules
As you all know I was one of the original TSM racers along with Jason, Scott, Keith, Roy, Lonnie, Brett, and others and we all had a blast back then. I personally never pushed a motor hard enough to have a block fail. I had rod fail but the block wasn't the cause. At the power level these cars are at now I think the motor difference in cost is no more expensive (or little) than using a stage block. I recently saw a stage 1 3.8 sell for around $1200.
Getting back to those 3 rules the class was based on.
1. 109 block
2. 70mm turbo
3. 3550 lbs min.
These were the 3 rules that were be the foundation of the class and supposed to never change even if there were other small changes allowed.
Well toss out the turbo rule when the turbos showed up that didn't fit the plug they just tossed out the plug (the measuring stick of the rule) instead of the turbos. For me the class lost integrety at that point and I never saw a point in trying to return. The argument at the time was what, why hold back technology it sorta kind of fits the rules we want to go faster. I personally believe there have been at least a few competitors exceeding the cubic inch limit over the years but with out a measuring stick what are you going to do.
I think Will has a good idea, I for one don't want to run TSE or TSL or TSO. I am just not interested in trying to go that fast or I would just do an LSX. I might even show up for TSM with my stage block if the opportunity was there.
Jason here is a thought if you want to wake up the car count. Open it up to what ever size motor they want to run just make 250 lb difference from 109 to 4.1/TA with a slot for the 3.8 closer to the 109 end of the spectrom. You might be very surprised at the additional cars that might show up.
Just the babbling of an old guy that likes heads up racing.
We have been running the same block for five years. If stage blocks are allowed in tsm we will put Tim's motor in my ths car and put a v8 in the banana.
Tsm was built around three base rules and if you change them you change the whole class.
109 are $400 to $600 and so far we have got five years out of one in the nines.
How much are stage blocks?
