Dusty Bradford
- May 24, 2001
If Stage blocks were allowed we'd be all for it.
The point of racing is for it to be
1) enjoyable...
2) repeatable
3) affordable.
One has to select parts that will hang at the performance level one wants to be at.. whatever that is... Once past that point, it gets old quick. This is the problem with "racing" and using stock parts... And the problem with classes that limit this... eventually gets old.. and car count dies.
The initial draw is running a stock block appears inexpensive as you already have one.. its the "it broke".. I now have 1000's of dollars tied up in the project and cant back out..
Stage blocks should be allowed and the rest of the rules remain the same. Problem is going to be cubic inch limitations because no one is going to find a plethora of 3.8 Stage 2 blocks. I dont know if the TA block can be had in that small of a bore or not.
I think the bottom line is taken what you can work with and pushing it as far as you can without going over the cliff... It really doesn't matter what class/block/turbo you have, someone will keep going...
We have been running the same block for five years. If stage blocks are allowed in tsm we will put Tim's motor in my ths car and put a v8 in the banana.
Tsm was built around three base rules and if you change them you change the whole class.
109 are $400 to $600 and so far we have got five years out of one in the nines.
How much are stage blocks?
Class organizers could always give stage 2 engines a wieght penalty.
Weight break for 109The cars are way too heavy now..
If TSM were to allow stage blocks, say good by to Mr.8847 and hello to Mr.71hpq again. I would make the switch. No of a few others aswell.
Do you think you can keep that beast together with a 71hpq.![]()
Yeah, I think so. Everybody has a bad day every once in a while. Wait a sec isn't your chit blown up right now to? lolDo you think you can keep that beast together with a 71hpq.![]()
Yeah it is hurt a little but after five years and hundreds of mid to low 9 second passes something had to give.....just saying.Yeah, I think so. Everybody has a bad day every once in a while. Wait a sec isn't your chit blown up right now to? lol
It so easy a cave man can do it. :biggrin:
