not much
ported heads and ported intake, bigger throttle body and plenum are definitely not needed until you want 10s unless your goal is to do it with 15-17 psi boost , i dont even run a ported intake on my 86 and stock plenum has been 9s with only a bored out stock tb
stock heads would need some porting for 10s unless your car is light
, hv pumps are not needed nor is high oil pressure , the stock bottom end can and has taken some serious power and held up reliably at 500hp (some fool has made over 600hp repeatedly for years running mid 10s )
dont detonate and things will stay together longer , detonate and even good stuff goes boom
for 10s repeatedly i would go with a steel shim headgastet and head studs ( or arp good bolts ) as it will take a minor tuning error without spitting the gasket and milkshaking the oil
stock cam will go 9s , flat tappet cams are risky but ive run one for years mid 10s , if doing a cam a roller is a wise move but youll also have to upgrade the heads (cut exhaust guides down) and upgrde to stiffer springs and consider stronger rocker shafts and shaft braces or TD roller rocker
figure well over 1000 just on the roller cam kit and head mods and thats without labor
good running engine without any compression , ignition , or voltage issues (gnttype.org spring cleaning and basics
replace all the vac lines and use zip ties
160 therm and good working cooling system
rjc powerplate (air distribution plate) under plenum
use good couplers and clamps on the intercooler hoses
duttneck on ic would help or go stretch or fmic
good 255lph fuel pump and hotwire for it, adj fuel regulator
upgrade the injectors to atleast 36s (stock 28s wont get you there without a lot of alky)
and get a turbotweak chip for the combo
get the brakes in order as youll want to build some boost at the line and youll want to stop, linelock for burnout
redo the valvesprings
look at the timing chain and replace if needed (some have already been done but you wont know till you look)
scanmaster is mandatory for starters and will help in tuning (
www.vortexbuick-etc.com ) also consider the powerlogger or wideband to get even more data but for 11.5s unless you have issues its not really needed
TA49, or tE44 (or todays equivalent 5856 or so)
stock D5 converter will work but a 2800 converter spools faster
the trans if healthy BRF might survive but typically 12.0 is the point where it should have a performance rebuild done and get a trans cooler
sticky tires , mickey thompson radials any size will get it done as 115 for 11.5 wont be winding the motor out too far
26"s are all you should need but the 27"(255/60) will do or the 28" (275/60) ,or slicks if you like them
Turbo tweak chip burned for your car
razor alky and r43ts plugs at .030 or race gas and r42s and a means to crank the boost up to 23psi or so
