L lazaris Active Member Joined May 25, 2001 Oct 26, 2007 #1 Whats a ball park number for VE's on an XFI with 160lb injectors. Aluminum head, 80mm turbo etc.
B Blazer406 Mechanical Engineer Joined May 2, 2002 Oct 27, 2007 #2 At what boost level? Ours seems low.... but the car likes it... At 20 psi boost (approx 240 kPa) ... we are around 60 on the VE table....at 6600 RPM 160# injectors..... SII.... 80 mm hairdrier.. aluminum heads....
B bison Moderator Staff member TurboBuick.Com Supporter! Joined Dec 19, 2005 Oct 27, 2007 #3 Blazer406 said: At what boost level? Ours seems low.... but the car likes it... At 20 psi boost (approx 240 kPa) ... we are around 60 on the VE table....at 6600 RPM 160# injectors..... SII.... 80 mm hairdrier.. aluminum heads.... Click to expand... Looks like about 1050 hp:biggrin: .
L lazaris Active Member Joined May 25, 2001 Oct 27, 2007 #4 Mid 20's psi for now. Im seeing mid to upper 40's White top's. Seems low?
