510TURBO
ALKYHOLIC
- Mar 17, 2009
thinking of buying some 19x9.5 rims all four with 35+mm offset will these rims fit a 87 T and if yes with what size tires? thanks in advance
SignUp Now!To answer your question "Will 19" rims work"? answer - YES! No problem!thinking of buying some 19x9.5 rims all four with 35+mm offset will these rims fit a 87 T and if yes with what size tires? thanks in advance
1-CLN-GN,
Sharp Car!!! Did you shave the frame rails or trin the wheel opening trim? Are you running the stock spindle or B-Car spindle? What offset/BS are you running front and rear. Other mods to run the 10" in rear? Where are you located?
Hot Air
