1968 Chevelle With '87 GN engine
They look great! Any new word on the paint scheme?
i just have to decide on the color of the stripe and what i want on it.
for example Do it match the stripe to the color of the wheel or the color of the other stripes already on the car. i am leaning heavy to the color of the stripes already on the car.
the next thing is What do i want on the stripes? Chevelle in script like this
I would match them to the color of the stripes on the car for sure.
I think the text should refer to the turbo motor if you plan to keep it in there which I surely hope. My preference would be whats on the buicks' hoods
"3.8 SFI Turbo"
"3.8 SFI Turbo"
Not a bad idea.
ill have to think about it thou. as i don't give out too much info and that would give it all up.
Yea its cool in idea but probably not the best.
I would say what ever it is it just needs to be timeless. Nothing that will look weird in a couple years.
this is the 2nd one that i have had to change in 3 months
So i ditched the hard plastic line and went with a hose from the Vacuum block to the MAP sensor
while i was at it i checked the PCV valve, it leaks like crazy So i now have to replace that too.
anyways i ended up removing and replacing the two back (PCV & MAP) metal vacuum lines with rubber hoses.
BTW its a PIA to get the zip ties on the vacuum block end of the lines.:mad:
i am now shopping for a good PCV or a good check valve.:frown:
12 bolt rear with 3.42s coming soon
it needs a to be rebuilt
Wow what a score man! Is that rear already 3.42? What gears have ya been with so far? I'm still rolling 2.73s. Think you'll be able to hit the track with them this year? GL!
they whir 3.31, which is what i wanted but no one is making NEW/replacement 3.31s so i am having the rear rebuilt and installing 3.42s
i'll post up some pictures.
i was using my stock 3.08s
:eek:WOW you ran me down on 2.73s :eek:
can you post up your time slip info?
3.42s is what I plan to use when I find a 12 bolt. Wont be for a while though.
Here is my breakdown of the run. Hopin to get back to the track next month for some colder weather. Gunna practice building boost at the line before I go.
60ft - 2.029
330 - 5.362
1/8 - 8.160
MPH - 87.32
1/4 - 12.682
MPH - 107.75
12lbChevelle...................Turbopowered68
60ft - 2.029 .......................1.936
330 - 5.362.........................5.307
1/8 - 8.160.........................8.137
MPH - 87.32........................86.21
1/4 - 12.682......................12.686
MPH - 107.75.....................105.15
i thought i was getting a deal but:mad:
with all the new stuff its getting sets me back $1445.00
and it does NOT include Axles, C-Clip eliminators or even Wheel studs.:mad::mad:
