I just finished this car last year. Ill try and give a quick run down on it. It has about 1,000 miles since done. Lemans Blue,White stripes. It had a rotisserie resto done on it. Body is lazer straight. Im sure I will forget things. The car makes a ton of power,and the body and paint is show worthy. Everything was replaced new,brakes,brake,fuel lines. Everything works in the car,but I dont have a radio for it. Heat is not hooked up but I have the fittings and hose. New blower motor,and heater core installed. If you see it and drive it, you will want it! Only reason Im selling is because I found another car I want ,but if it sells before I sell mine I dont think I will want to sell anymore lol! I have over $32000 just in parts alone without labor. I have bunch more pics interior,and underside also. Im asking $32,000 o.b.o. 484-390-3164
Motor...
Factory 4 bolt main block
Steel GM crank
Crower Rods
Forged TRW's 10.1 compression
Hydraulic Roller cam
Edelbrock RPM heads
Comp. Gold roller rockers
Edelbrock RPM intake
Nickerson flowed 750 carb
Moroso pan with kick outs and trap door
Aluminum water pump
MSD 6AL
MSD Billet Distributor
Hooker Super Comp coated 1 3/4 headers
March serpentine pulleys
Aluminum rad with electric fan
Factory Power Steering
Trans...
5 Spd Tremmec just rebuilt
3 inch steel drive shaft
Ram clutch
Ram SFI flywheel
Blowproof bell
Rear...
Factory 12 bolt just done a week ago
3.07 gears (believe me it dont need anymore)
T/A Cover
Suspension...
All hotchkis suspension
2inch drop springs front
1 1/2 rear springs
Front sway bar
Full poly bushings
Interior...
Mostly factory in good condition
New dash pad/carpet
Rosewood Wheel
Needs head liner which I will have installed
Body...
All I have to say is come look at it in person!
DSE Electric headlight door kit.
Endura bumper
Wheels...
Factory Ralleys
Exhaust...
Custom 3 inch x-pipe with Turbo mufflers
No tail pipes (my preference)
Motor...
Steel GM crank
Crower Rods
Edelbrock RPM heads
Aluminum water pump
MSD 6AL
Trans...
Ram clutch
Ram SFI flywheel
Blowproof bell
Rear...
T/A Cover
Suspension...
1 1/2 rear springs
Front sway bar
Full poly bushings
Interior...
New dash pad/carpet
Rosewood Wheel
Body...
Endura bumper
Wheels...
Factory Ralleys
Exhaust...
