iraceitall
- Dec 21, 2012
I rescued a 79 Lesabre Sport Coupe from the salvage yard, mostly because of the cool 2dr body, but when I discovered what I had, I decided it needed to be raced! I already have an 82 Grand Prix with the 252 being built for NHRA Stock Eliminator, but this intrigues me even more.
Here's the deal, car has to weigh 3540lbs less driver, keep stock engine and components with no porting, I can run any duration cam but must keep stock lift, roller rockers, up to 9.3:1 compression, stock turbo but as much boost as it can handle, stock Q-Jet, headers if available. Do you think I can get this monster to run low 13's like this?Just how much boost will it take? Any recommendations on converter (TH350 trans) and gears (4.10?)? I will be using a 29" tall slick in back.
I have messed with turbo 2.2 Mopars, but this is new territory to me!
Also, anyone got the airbox that fits on the carb? This one was missing the carb and box, but I have a carb tracked down from a 79 Riv turbo.
 He should be able to help you figure out what you want to do to get the most out of it.
