This is whats going on.I have currently gathering parts for my 1980 hot air turbo 3.8 motor rebuild.I plan on being in the power levels on 400hp or 450hp power levels with this rebuild.now what i want to know is how much power can the hot air buick pistons and crank handle,I am not trying to buy a different crank and forge pistons unless its needed inorder to support the horsepower levels safely.
Here are the parts below that I already had from a diffent project and brought off ebay.this is a blow through intercoler setup.
- ebay turbo buick exhaust v6 manifold with t3 adapter.
- stock gnx intercooler with 6' electric fan.
- reworkd oil pumpcam is to be determine maybe stock.
- holset hc1e turbo older version of the hx40 turbo.
- holley dominator intake(ported)
- stock heads reworked with sbc Valve Springs 550 Lift Seat pressure is 110lbs @ 1.750", open pressure 325lbs @ 1.200". Coil bind at 1.15". Free height of 2.035".
- pro jay intake elbow with 8 injector bosses 8 21 pounds stock L98 injectors stock 90mm mustang throttle body.
- thrust accel dfi ecu,wire harness.
- ls1 maf sensor.
- mallory ignitionbox,remote igniton coil and new distributor.
