1987 Buick Grand National amazing race car for sale
dementd
Selling 1987 Buick Grand National. specs and pictures as follows:
Engine: 274 CID Buick V6
Block: Stage II 4.20’’- Bore-Studded Mains-Billet 4 Bolt Caps- O Ringed. Bored & Honed with plates-Machined for Danny-B Retension Plate.
Crank: 3.625 Stroker-Crossed Drilled-Gas Nitrided-Polished.
Rods: Carrillo Rods-Have Been Mag’d-Full Floater.
6 JE Forged Custom-Nitro Coated Dome-Graphite Skirts
Heads: Fully Ported Stage II Aluminum-Titanium Intake Valves.
Severe Duty Stainless Exhaust Valves-Packaloy Springs
T&D 1.65 Shaft Rocker Arms-.080 Moly Push Rods. Flow 400 CFM
Additional: Sheet Metal Valve Covers-Custom Alum .Oil Pan- High Volume. Front Cover-High Volume Oil Pump-Mezeir Electric Water Pump-BHJ Balancer-Alternator Mount Kit- Hell Fire Rings-Roller Timing Chain-Clevite Rod & Main Bearing-After Market Solid GN Mounts-Comp Comp Cams.0180” Offset Solid Lifters.
Trans: Built Turbo 400 with Trans Brake
Hurst Piston Grip Shifter with custom mounting plate in console
Converter: Cone Stall 4250
Strange Rear End With 390 Gears With 33 spline moser axles & spool.
Wilwood twin piston Disc Brakes ( Rear )
Fast Computer System.
160 psi Injectors.
Turbo: 88 MM
NOS Nitrous oxide system with bigshot polished solenoids to spool the turbo on launch with hob switch.
Hurts Line Lock
Custom made chrome molly Anti-Roll bar
Umi Performance Double adjustable upper control arms
Umi Performance Double adjustable Lower control arms
UMi Performance Tubular Lower front control arms
Moser trick springs both front and rear
Competition engineering adjustable shocks front and rear
Weld pro star rims with Hooser quick time street legal racing slicks
Custom bent Chrome Molly 10 point Roll cage cert’d to (8.50)
RJS racing 5 point harness both driver and passenger
Miles on body: 72,000
Car has T-tops
The Grand National ran a 9.30 @ 150 MPH.
Car ran number above with low boost, and wrong rear end gear. motor has been 7.79 @178 mph with twin turbos in white racing buick grand national that beat Dan Millen in the famous burn down final and crash at milan dragway's 10.5 outlaw race.
Car is fully streetable, tuned for race gas, and drives like a stock GN when not under boost. under boost its breath taking on the street and track.
Engine has over $25,000 invested with no part or cost spared.
ASKING $42,500.00 OR BEST OFFER.
People are gonna ask for more detailed pics or links, I'm sure. I'd like to see some.
Why would you want to sell this? This motivates me to work harder (so i can own this). Did you build this yourself?
That's a steal for what's into that. Someone gets to buy it at half price. Finally a top notch car for sale. I was beginning to wonder if there were any left. What a beast!
No i didn't build this myself. White racing in Warren Mi built it for me. It will be at the Woodward Dream Cruise .
I assume it has notched frame, reverse valve body? Any pice of the interior? Will you be at the Moose Preserve on Woodward Wednesday 18th? Very Nice car. Add AC and it is one sweet street car.
Yes, I'm bring it to the moose on Wednesday.
