1st time rebuilding a 2004r myself
dank GN
BlackArts Automotive (661)993-8277
So I decided that I want going to mail my trans back and I will try my hand at a soft rebuild . Basically I got it apart and noticed it got crazy hot . A trust washer gave out and took out my pump . Sent the parts out for a custom Bearing setup should be back next week :-)
Last but not least the washer that caused this . I can't believe such a inexpensive part can cause such a headache
The washer did not cause this failure. The screws that hold the stator were left loose or left out and caused this problem. Did you find the bolts in the pan?
I would rather not say . He is taking care of it though . And no I didn't find a torq screws anywhere :-( does that connect that shaft to the back of the pump ?
That trans took some hard launches . if those bolts weren't in Dave wouldn't it fail right away ?
Yes it connects the stator to the pump
Not right away. The stator support fits snug in the bore of the pump and it supports the stator in the converter from spinning. If the pin in the stator support and screws were not there, it would have failed immediately. In your picture, you can see the twisting of the stator support and pin that broke the pump. Failure had nothing to do with the washer, just the necessary screws not being installed.
Get your converter checked also.
Converter got a clean bill of Health . My converter guy just said it got crazy hot .
Thanks for your professional eyes a few more pics
Can u see the scratches is this something I should be concerned about I'm pointing to it with the tip of the pliers
I was under the impression that you should replace the torx screws with bolts so that's what I did on mine.
If the clearance was left loose could the thrust washer get pounded and fail causing this? Or I guess if the fasteners weren't installed.
Great pix, and great tech from the professionals.
^^^this
That would be very unlikely. The only time that washer is hurt (when the bolts are in place) is when it's setup too tight. Look at the helix of the gears. That explains it.
So, loose is good (or ok) on that end? I had a hard time finding a yellow washer though I did find the thinner ones.
I don't know what you mean by loose. Too loose is no good and too tight is no good. If you were a little tight 2 case to pump gaskets could be used.
Good stuff . I measured it and wrote it down but I don't have it handy with me. I remember it being in the loose end of the spec in the atsg manual. I did put the yellow washer in to tighten it up from where it was with the original washer.
Keep in mind the front end play does not include the end play between the snap ring on the end of the input and the od carrier. If you include that clearance you will be too tight.
I pulled the input up to the snap ring then measured clearance from there. I noted the measurement when I could feel the snap ring, the pulled the input to its max to get a second reading. The difference between the two readings becomes the clearance. Am I explaining that correctly?
I'm no trans builder, just a hobbyist on a tight budget. Thanks for your help.
Yes. For more fine tuning you can sand a couple thousandths off the thrust washer if you have a flat surface to sand on.
