2004r Hi-flow Filter And Sump Kit
chris718
As We All Know, The Stock 2004r Filter Has Trouble Picking Up Oil From The Pan Because The Pick Up Points Up.And Is bstructed By The Valve Body. This Upgrade Allows The Use Of The Late Style 700r4 Bottom Pick Up Filter Without Any Interference Problems. An Aluminum Rail Is Placed Between The Two Pan Gaskets To Extend The Sump To The Proper Depth When Using The Deeper Filter. Also, An Insulated 4th Gear Pressure Switch Connecter Is Included To Eliminate Grounding Of The 4th Pressure Switch When Using The Updated Filter. Kit Also Includes 16 New Black Oxide Pan Mounting Bolts Which Are Longer To Work With The Aluminum Plate And Extra Gasket.$84.99.
I installed one of these on a trans last week and it worked great. Very easy install.
nice. this will be good for the people that cant spend $$$ on the bottom feeder pans.
