2004R trans/ great for daily driver
brian
Senior Member
Excellent daily driver...
Street/Strip 2004R lock up.
This unit has a Monte SS CZ hi-po valvebody (model), and this trans has all the usual parts. Larger boost valves, pump ring kit, Alto clutches (extra throughout) and wide Red band with our shift calibration.(shift kit)
This unit is a lock up with a billet servo. The input shaft and drum are hardened. Has a stock pan with a custom baffle for fluid control, and a drain plug installed.
The governor on this unit is pinned, and will provide WOT upshifts near 5300. With all correct wiring and switches for a GN, with the correct black plug.
Price on this unit is $1850 with shipping in the U.S. (continental 48) This price includes the core.
This transmission can be run with a 12 inch or fimilar 10in hi-po converter. .
You can also search the trans forum for info on the CZ valvebodies.
This build, when used with the correcct converter is easily capable of running well into the 11`s.
We could add a brake if desired.
Thanks, Brian
Any questions please shoot me an email: hipsibri@cs.com
View feedback in that forum under brian, Brian`s Transmissions
I can here this lonely trans crying at night. Just waiting for a new home!:D
Send me a BRF core back with this, and we can cut $400 off the price.
Brian:p
